Change SIM Card PLEASE HELP
paulhern
Hello,
I have had some issue's getting my account running as I ported from Virgin. I can not access my self serve account and need to change my SIM so I will have a working phone again.My details are below
Paul Hernandez
Edited: Removed private information  ShawnC13
2 REPLIES 2
Mary_M
Retraité / Retired
Retraité / Retired
Good afternoon @paulhern,
This is just a reminder that I've responded to your private message 🙂
Regards,
Mary
** Please do not post private info such as: phone number, account number, pin etc.. This is a public forum. **
Dunkman
Hi Paul,
Please do not put your private information on a public forum.  Anybody can view your information.  You can edit.  You need to private message one of the PM moderators for help on this issue.  Usually takes up to 4 hours to port.  If beyond that time frame, need to contact moderator.
Here are the instructions to contact moderator:
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-How-to-Contact-our-Community-M...
