Cell problems cant call
Sandy_1
  • Irecently change y number n it d8ne something where I can not make calls or texting.   If someone 1 text me on my old number it goes threw  HELP PLEESEE
2 REPLIES 2
Sandy_1
Did n nothing  I contacted cs n there looking into it.  Thanks 4 help
@Sandy_1
Try rebooting your phone by powering off then back on and reset the network setting.
If that didn’t work contact a CS_Agent to investigate the issue.
