Cell phone
NorBorg
How do I add 2 cell phones and do I have to cancel my rogers account for the cell phones
@Anerkons
yes, email alias would work.  But make sure you remember what alias you created.  Many got into login trouble as they were unable to find out the alias used
Anerkons
@softech wrote:
@NorBorg
do not cancel your Rogers account if you are planning to port those number into PM.  Only numbers from active account can be ported
and  PM system is one email address for only one account.  There is no family/combined account here.  So, if you need to subscribe 2 plans and transfer 2 numbers into PM, you will need two email addresses to create two different account.  Start subscribing with one account first.  After the account is fully setup and number ported, then login My Account and get the friend referral code to use for subscribing your second account.  You will get a one time $10 credit with that second account, and 1 Public Point (= $1 value) per cycle for your first account for referring
Would an email alias from an existing registered account  be accepted to setup another account - ?
@NorBorg
