10-23-2020 04:00 PM - edited 01-05-2022 03:52 PM
French side
Whatever issues or updates were done the other day has messed up the buttons. Using Chrome on a Cell Phone.
Notice in screenshot below you can hardly click the bravo button. It was never like this until whatever happened a few days ago.
Is it possible to get it fixed?
Thank you!
10-26-2020 04:28 PM
@David_J Thank you!
10-26-2020 02:55 PM
@Jb456 - thanks for highlighting to us. We made a change and believe the issue is now fixed.
Thanks again,
David_J
10-23-2020 07:53 PM
I also have noticed that on Safari web browser, the links are "off" and need to click above the various link to work. Worked fine with Chrome browser at work though.
10-23-2020 04:25 PM
@computergeek541 I have given Bravo's on the French side that is not the issue.
I just found one of your posts on the French side and gave you a bravo.
The issue is when you start a topic. The "Mark as Solution". Is now over the bravo button which never was like that before whatever happened the other day.
English side
French side
So if they can just move the bravo button over like the English side. It will be fine.
@totalUser ya but that is to much work. Can get to it in Desktop Mode also but again to much work lol
10-23-2020 04:07 PM - edited 10-23-2020 04:09 PM
@Jb456 The bravo button in the French side of the Community hasn't worked properly for so long that I can't even remember how long it's been. Public Mobile knows about this issue. At one point, I thought that this was fixed, but it's also possible that I could have been mistaken as I could have been looking at a thread that already had a solution (which re-arranges the buttons).
In summary, bravos can't be given to anyone on the French Community website if the mobile version of the page is being used. The only way that I know of to get around this is to use the desktop view website.
10-23-2020 04:04 PM - edited 10-23-2020 04:10 PM
Try rotating or using different browser or even device until it gets resolved
