Carrier Transfer/Activation Mistake
ncheng02
Hi, I accidentally mistyped my phone number when inputting it for number transfer/activation. How do I get it fixed asap?
2 REPLIES 2
slusagm
you can call the PM porting team, but you need to enter the "wrong" number to get to live support
you can find out what wrong number you put in by checking your phone with PM sim.  I should be able to make outgoing calls.  Call someone who can tell you what "wrong" number it has now.  Then call poring team and punch in that wrong number (but porting team is now closed, you have to wait till tomorrow morning)
For the porting team number,  I can't post the number here, but I will message the number to your community inbox.  Please check and call them
But if you cannot reach them or they said they cannot help, you will need to contact PM using this link
 And CS_Agent will reply to your community inbox, check here:
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
hi @ncheng02
since the number was wrong, you will need to ask PM  support agent to correct it.
 you can submit  ticket by direct message:
