Cannot send texts.
01-07-2020 12:49 PM - edited 01-05-2022 08:55 AM
01-15-2020 09:34 AM
@computergeek541 It seems that it has something to do with Mms text messages. Especially with pictures and videos. Dat has to be enabled to do this. So if the settings are wrong, no mms texts
@Franny Thanks for choosing a solution.
@computergeek541 wrote:
@Franny wrote:Hi Deputy mayor.
Your info was what I needed!
Thanks a million.
I may send you a text!
Franny
I'm very confused, but as other have said, APN settings and other data settings have nothing to do with text messaging. If your issue was that you could not send text messages, any amount of changes to APN settings could not have fixed the issues that you were having.
01-15-2020 09:16 AM
I have alreadt thanked this person for correcting my problem.
Thanks again!!
Franny
01-08-2020 02:26 AM
Thanks a million.
Franny
01-07-2020 01:43 PM
Hi Deputy mayor.
Thanks a million.
Franny
01-07-2020 01:05 PM
Hi @Franny
Dies it happen with every messaging app you use?
Can you check with different apps?
Also can you try In another phone too make sure it's not your account that needs reprovisioning
01-07-2020 12:55 PM
@Franny wrote:Hi . Ever since I set up my Samsung A5 on public mobile, I cannot send texts. I have discovered that data is missing. for example : APN, MMSC, MMS proxy, MMS port, APN type.
Where and how do I find this information?
Thanks.
Franny
APN has no relation to texting other than MMS which is a different kind of texting.
01-07-2020 12:55 PM
Thanks.
Franny
BTW, regular text message does not need data. Picture MMS needs data.
Try the simple procedure first by enable data and restart your phone.to cetting your APN automatically.
01-07-2020 12:52 PM
- Touch Settings.
- Scroll to and touch Mobile networks.
- Touch Mobile networks.
- Touch Access Point Names.
01-07-2020 12:51 PM
They should be as followed.
