Cannot make calls - long distance addon error
ShahidaS
Hi,
I cannot make local calls. I'm in Toronto.
I get the error "sorry cannot make the call. This call requires long distance addon.
Please help!
9 REPLIES 9
srlawren
@Anonymous wrote:
@ShahidaS, could you have used up your allotment of 50 minutes?  Did you check in your self serve portal?
@Anonymous bingo.  @ShahidaS this is why I was asking if you are on the $10 plan.  It sounds like you have used up your minutes.  You can check by signing into your self serve account.  On the Overview page (the one you land on after signing in), in the lower half, if you see your minutes used showing as something like 34 / 50, then you have not used up your minutes.  If you don't see it listed at all, then you have used them all.  If you've used them all, you can purchase either the $8 200 min Long Distance add-on, or the $15 400 min Long Distance add-on keep making and receiving calls.
SD08
@srlawren wrote:
@SD08 wrote:
@ShahidaS wrote:
Hi,
Please help!
@ShahidaS That message is sometimes generated erroneously.  Try adding a 1 or +1 in front of the number, that often lets you bypass it.
@SD08 I think that message you're talking about is a bit different, it's along the lines of that the call may cost you long distance charges.  A bit different.
Ah, okay.  I was thinking the situation of not being able to call a number covered within the calling plan was similar, but I couldn't remember the wording of the message where the +1 applied.  Thanks for clarifying that.
ShahidaS
$10 plan. Its not a new activation. Im not trying to make a long distance call. I tried adding 1 n +1... doesnt work...
srlawren
@SD08 wrote:
@ShahidaS wrote:
Hi,
Please help!
@ShahidaS are you by chance on the $10/50/50 plan?
SD08
@ShahidaS wrote:
Hi,
Please help!
Alex888
Try going into your account, reporting your phone as lost/stolen, log out, wait 10 minutes, log back in and report it found.
ShahidaS
Not new acfivationNo
@ShahidaS, have you dialed the same number before without any problem?  Is this a new activation?  Even after you get the message, does the call go through?
