Cannot make a call
01-29-2021 10:07 PM - edited 01-06-2022 01:58 AM
my phone says I cannot make a long distance call without an add-on when I am just trying to make a local call
Service
01-30-2021 01:51 AM
@PIM :Have you dialed this number from your phone before without any issues? Can you d dial other local numbers
01-29-2021 10:23 PM
@PIM wrote:my phone says I cannot make a long distance call without an add-on when I am just trying to make a local call
Is the message one fo the following?
-talk not included
-you do do not have an active long ditsance add-on
-long distance charges may apply
The last message can be ignored and the call will complete. Try dialing a 1 before the area code of your number. I know that you should have to do that for a local call, but this might work.
