Cannot connect to service
ljayne
I switched from Telus two days ago. My phone number didn’t get transferred from them until the next day. Now I can’t get service from Public on my phone. My new SIM is activated
@ljayne  -
Is this a 'new to you phone' check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
Otherwise if a restart or trying the sim into another phone does not help, see @softech 's post to submit a ticket to CSA to check status of the new sim/account.
@ljayne
Try rebooting your phone and see if that works. Hold down the power button and power off then turn the phone back on,
@ljayne   so, was your sim card working well on the first day ?
If you have another phone around, try to put your PM sim card there, this could force a provisioning and might resolve your issue.
Ori if you don't have another phone, at least try to reseat your sim card , power off, take the sim card out for a minute before putting it back and power up
Also, you can try to Reset Network Settings and see it it works
If issue persists, open ticket with PM Support, they can reprovision the account from their end:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
Timer
@ljayne
contact PM support team by private message CS_Agent
