Cannot connect to mobile data.
04-12-2019 07:17 PM - edited 01-05-2022 04:20 AM
Phone is an LG XPower. Phone works fine for calls and text as lon as there is no picture in the text. I followed apn setting instructions from the help bot but to no avail. Anyone got any suggestions? Is there a place to take the phone to make sure all of the settings are correct. This phone was on Telus previously and their people unlocked it for me.
Phones
04-14-2019 06:32 PM
Thanks. I'll try that tomorrow. I really thought this would be easier.
04-14-2019 06:03 PM
@Dekadaddy wrote:I did as you suggested and got nowhere. Have you got any other ideas?
Did you write a message to the moderator to have some help from them? Here..https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 and give them details of your problem. And be patient waiting time is few hours to 2 days.
04-14-2019 05:58 PM
Good idea but no joy
04-14-2019 05:15 PM
04-13-2019 04:49 PM
@Dekadaddy wrote:What is involved in a network reset?
Network reset to clear the setting for the WiFi passcode and mobile data APN to their default.
If your phone does not setup the APN after phone reboot, you need to update APN manually.
04-13-2019 04:40 PM
This would delete any custom entered APN settings, saved Wi-Fi networks and passwords, and few other things relating to connectivity.
@computergeek541 I thought he meant as in, what is involved to perform a network reset, but he probably meant more of what you said.
04-13-2019 04:38 PM
04-13-2019 04:38 PM - edited 04-13-2019 04:38 PM
@Dekadaddy Go to your network settings find network reset, click it, then click yes or ok
04-13-2019 04:32 PM
04-12-2019 08:06 PM
@Dekadaddy wrote:Phone is an LG XPower. Phone works fine for calls and text as lon as there is no picture in the text. I followed apn setting instructions from the help bot but to no avail. Anyone got any suggestions? Is there a place to take the phone to make sure all of the settings are correct. This phone was on Telus previously and their people unlocked it for me.
For LG phone, do a network reset. Your data should be working after restart your LG phone.
04-12-2019 07:58 PM
Did you try to reset the APN settings to default?
In the APN settings menu sellect the 3 dots and reset to default.
Then you may have to add a new Public Mobile APN entry.
04-12-2019 07:25 PM
@Dekadaddy If you correctly set the APN, try setting the APN type to default only. If that doesn't work, you might have to do network or factory reset as some LG phones requires. Make sure to back up everything if reset.
04-12-2019 07:20 PM
Did you check here for APN...https://apn-canada.gishan.net/en/apn/public-mobile?
![](/skins/images/C206B3E09108DC4A8294A110EB9CCA46/responsive_peak/images/icon_anonymous_message.png)
