03-30-2026 02:46 PM
I switched to public and transferred my phone number from chatr mobile. However, I cannot receive calls. How can I resolve this?
03-30-2026 02:57 PM - edited 03-30-2026 02:59 PM
Ok, in order to port you must receive and confirm that was your intention.
You can create a ticket for the agent to assist you or check your inbox for another reply from slusagm with the phone number to contact to re-do the port.
03-30-2026 02:50 PM
I don’t think I got a sms confirmation from chatr. I did this transfer two days ago.
03-30-2026 02:48 PM
How long ago did you port in?
Did you reply to the sms confirmation of the port?
Disable the previous sim and insert or enable your Public Mobile sim and make it sure it's set as primary and restart your phone.
03-30-2026 02:48 PM
could be a stuck port
there is a porting assistance team you can call and ask for update. I can't post the number here, but I will message the number to your community inbox. Please check and call them
But if you cannot reach them or they said they cannot help, you will need to contact PM using this link
And CS_Agent will reply to your community inbox, check here:
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
