05-20-2018 11:56 AM - edited 01-05-2022 04:48 AM
Good morning,
My account number is ************, and I am looking to cancel my account including automatic withdrawl effective immediately
Barbara Berridge
05-20-2018 11:37 PM
I'm guessing that if you're leaving PM then you're also a new customer for some other carrier. And you may wish to keep your existing phone number.
If so, then it is best to get your new carrier to do your Mobile Number Port. PM doesn't need to be involved (or even informed), but the MNP will be much less problematic (and quicker) if the phone number is still active on your old carrier (PM) at the time your new carrier processes the MNP request. A botched MNP can result in losing the phone number forever. I'd advise allowing for (paying for) a little overlap between your old/new services, maybe a few days or even a week, just to ensure that there's basically no risk of losing your phone number if there's any problems or delays.
05-20-2018 01:35 PM
@barbaraberridge, make sure you remove the credit card itself. If no credit card on your account, they can't charge you. A safeguard I guess. Or maybe am just take precautions!
05-20-2018 12:06 PM - edited 05-20-2018 12:07 PM
@mimmo: Thanks for pointing that out. Updated my answer 🙂
05-20-2018 12:03 PM
@Cheetah24 mods can't really do anything. The account just needs to cycle through to become expired. And that's it.
05-20-2018 12:01 PM - edited 05-20-2018 01:22 PM
@barbaraberridge just remove autopayment. Your account will be active till your end date. Then 90 days after it will be closed for good, and your number will be gone (ability to be reassigned to someone else in the future).
05-20-2018 11:59 AM - edited 05-20-2018 12:04 PM
Hi there,
Sad to see you go. But for this you'll need to contact the moderators through a private message.
Click here to send the moderator team a private message.
You can find information regarding the moderator team by following this link.
Hope this helps. 🙂
UPDATE: Please see the below answer; my anser isn't accurate.
