Cancel autopay
mkgilbert2017
Hi:
I would like to cancel autopay but cannot find what SIMon is telling me to do as under the Payment tab I do not see anything that says to remove autopay.
Please help.
Thanks.
darlicious
@mkgilbert2017
Autopay is called pre-authorized payments now. You can disable it under "manage my card". Or if you are in the old rewards program and you still want to earn your $2 auto pay reward you can change your credit card on file to spent credit gift card. If you do not have one private message me I will give you the info of one of many that I have that I can share to enter so that you don't lose the reward but you will not automatically renew your plan.
tina9099
After logging into your PM account, go to payments and if you scroll down a little you will see manage payments.  Click that and then click the check mark in which you will get a pop up screen and you can disable autopay. Hope this helps!😊
dust2dust
Click on Manage Payment Method.
Adding - @RossN - Good spotting. Normally I see those things. And I even thought wow back to back. Odd. lol
RossN
@mkgilbert2017 hi you just posted this question did you not get the answer you needed?
