05-21-2022 11:49 PM
Hello,
When I set up my PMobile account, Autopay was turned on automatically. However, it was stated that I could switch this off by going to my self-serve account. I've gone to the latter account, but I can't find how to cancel Autopay. How do I do this?
Thank you.
Payment
05-22-2022 09:10 AM
@Dawven - another method to removing autopay from your account would be to dial 611 from your Public Mobile device, or call # 1-855-478-2542 (need your 4 digit account PIN for this method) from another line to do so.
But, if this is due to because you are porting out your PM number to another provider, or you simply want to cancel your plan, then best to log into self serve to remove any payment card attached to your account first.
05-22-2022 12:01 AM
Depending on when you joined PM you will be losing your autopay reward of $2 IF you are still on the old rewards program. If you are you can always just leave it activated and pay for your plan before it ever gets charged to the credit card on file.
05-22-2022 12:01 AM
Login to your account>Make a Payment>Edit your AutoPay Preferences>click on Remove AutoPay.
05-21-2022 11:56 PM - edited 05-21-2022 11:59 PM
Log in to your account / Payment / click Automatic Payments and turn off Autopay.
