01-12-2026
02:58 PM
01-12-2026
03:24 PM
computergeek541
I need to cancel an account for a phone but the phone number and email associated to that account are no longer valid
01-12-2026 03:02 PM
hi @
you really don't need the phone number to port out? If you need the phone number to transfer, you cannot close the acocunt
But if you don't need the number, you will have to ask PM support agent to help to cancel the service. You can simply ask them to remove the credit card. You can submit ticket by direct message:
01-12-2026 03:01 PM
ask PM to help to close the account.
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
