09-11-2017 05:56 PM - edited 01-04-2022 02:37 PM
Hello,
I'm a Public Mobile user living in Toronto with a plan that is only Ontario province wide (talk + data).
I'm planning a weekend trip to Quebec City. Since my existing plan is only Ontario wide, if I wanted my cell phone to work with talk + data, would I simply purchase the following add-ons?
Data 200 MB $10 or 1GB $30
Long Distance 200 mins $8 or 400 mins $15?
Thanks.
09-11-2017 06:20 PM
Hi 123justin,
Indeed, the data will work. 🙂
As the part of a Customer Service Experience, I am inviting you to fill out the following survey: https://telus.eu.qualtrics.com/jfe/form/SV_6tzYQ56VOqX4teZ
Have a nice day!
Cheers
Abdoulaye
09-11-2017 06:16 PM
Oh that's right, I forgot data was Canada wide.
Thanks for the quick reply.
09-11-2017 06:04 PM
You would only need a calling add on. Data and text work Canada wide. Or you can use Google Hangouts to make calls, it will just use some of your data
![](/skins/images/02B49C0B2FC614613D221373CF8AAEF5/responsive_peak/images/icon_anonymous_message.png)
