02-27-2022 10:50 PM - last edited on 02-28-2022 12:29 AM by computergeek541
I have a Realme 8 5G that has been working great for me on the public mobile network with one exception.
There are only a few people that I can send and receive text images from. Most people send me an image and I get a message to download it but it won't download. If I try to send an image to those people I get a failed to send message.
Has anyone experienced something like this and figured out how to fix it?
The fact that sending/receiving images from a few people works leaves me baked as to what the cause of the issue is.
02-28-2022 10:11 AM
This worked great!
Thanks for your help!
02-28-2022 12:28 AM
For APN type, try changing it from default to default,mms (no space before or after the comma)
02-28-2022 12:27 AM - edited 02-28-2022 12:28 AM
@Brhildebrandt : Right. BKNS27 will likely be right.
APN Type = default,mms
Add a comma and mms after default. No spaces. Lower case.
Edit: Might need some alteration to the last two at the bottom. But let's see what happens with ,mms.
02-28-2022 12:22 AM - edited 02-28-2022 12:24 AM
Here are my current settings
02-27-2022 11:49 PM
@Brhildebrandt : The easiest for us would be if you could post screenshots of your currently active APN settings from top to bottom.
02-27-2022 11:31 PM
Do you mean set to a MMS APN instead of a Global APN?
02-27-2022 11:30 PM - edited 02-27-2022 11:44 PM
Everything works on wifi or data except for sending images via text.
Not sure what you mean by RCS. The APN settings should be good. I have them set up as noted on Gishan.netI have been playing around with it a bit tonight and it appears that if I unselect an option to "only send SMS/MMS messages" then I can send images to other android phones (not iphones) when I have wifi but not on mobile data.
UPDATE - It appears I had a setting wrong and I can send images via mobile to other android users
In no instances can I send images to iphones
02-27-2022 11:11 PM - edited 02-27-2022 11:12 PM
Check the APN type setting to see if it is on mms
02-27-2022 10:56 PM
@Brhildebrandt : Can you otherwise browse the internet with cell data (not wifi)? Do you have your texting app set to use RCS? I then also wonder about your APN settings.
