Can't reset password
gwmatthews
Have tried a dozen times already, across several browsers. Get this message every time
ForgotPassword/LoginUnsuccessfulUser_LoginDisabled
Jackhyf63
Unfortunately you will need send a private message to the moderator team with your phone number, PIN, and an explanation.
Did you set up the self-serve account?
Lieux
You can write a message to the moderator here..https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 and explain to them your problem. They will help you. Waiting time is few hours to 2 days.
