03-31-2020 11:05 AM - edited 01-05-2022 10:10 AM
i cant activate my sim
Separate posts on same topic merged by SD08 from Announcements to Getting Started; title edited to reflect subject.
03-31-2020 11:48 AM - last edited on 03-31-2020 09:50 PM by SD08
@Dwl wrote:i keep getting invalid sim
i bought 3 sim cards online and get my phone to activate
david williams
David, 1st of all, this is a public forum, and you most definitely SHOULD NOT include any personal information, such as your email address. Secondly, you're better off starting a new thread of your own, rather than posting at the tail end of multiple other threads. Lastly, it helps if you provide a little more detail of what you've done so far.
In order to get rid of your included email address, I suggest you go into all the threads you've posted in, and click on the 3 dots in the upper, right corner of each of your posts, click on "Edit", and then edit out your personal info.
03-31-2020 11:34 AM - last edited on 03-31-2020 09:49 PM by SD08
david williams
03-31-2020 11:07 AM - last edited on 03-31-2020 09:48 PM by SD08
@Dwl wrote:i cant activate my sim
Edited by SD08 to remove OP's e-mail address from quote
(Dwl you might want to choose the 3 dots on the right hand side choose edit reply and remove your personal address from your post. This is a public forum for all to see)
Can you give us a bit more information?
What type of error?
If you are getting an error in your browser then try again but first clear your cache/history. Close browser and open a new one in incognito/private mode.
Are you on the this page https://activate.publicmobile.ca/
