02-04-2020 08:17 PM - edited 01-05-2022 09:21 AM
Whenever I try to get started and activate my sim it doesn't load the page
02-04-2020 09:21 PM
@Benselic As I mentioned earlier....with koodo or pc mobility prepaid you must activate with a temporary number first then get the moderators to transfer your number over for you. It cannot be done by you. You could contact the moderators now because it is unlikely you will get a response until tomorrow at the earliest. Meanwhile you can get your services working with the temporary number.
02-04-2020 09:14 PM
@Benselic wrote:is it possible to activate my public mobile sim card and get a new number then port my old koodo prepaid number to public mobile later? or do i have to port right away before registering
Yes sign up and take a new number..make sure you keep Koodo prepaid account active...
Then log into your account and try change number
It might be same outcome that you can't transfer....
So follow instructions to contact moderators listed on above post.
Don't forget to enter a referral code for$10 signup bonus
02-04-2020 09:13 PM
02-04-2020 09:12 PM
02-04-2020 08:48 PM - edited 02-04-2020 08:48 PM
@darlicious what's this? Are you trying to be @CannonFodder ed?😉
@darlicious wrote:@Benselic There can be several reasons why you can't port your number. Are trying to port a number from pc mobility or koodo prepaid accounts? They require moderator hrlpbas they share the same back end as public mobile.
Are you the account holder? Is it from a business or corporate account? It could be your location there are some phone numbers that can't be moved to or from a certain area the provider doesn't have any phone numbers in that area.
02-04-2020 08:45 PM - edited 02-04-2020 08:52 PM
@Benselic There can be several reasons why you can't port your number. Are trying to port a number from pc mobility or koodo prepaid accounts? They require moderator help as they share the same back end as public mobile.
Edit: @gblackma unautocorrected
02-04-2020 08:42 PM
I am using Opera browser on Windows 10 and it works fine.
No luck with Chrome, Edge, Firefox browsers.
02-04-2020 08:38 PM
@Benselic If you are activating and trying to port take a temporary number instead. Get all of your services up and running first. Then you can go into your self serve account and port your number in later by using the change number feature.
02-04-2020 08:35 PM - edited 02-04-2020 08:35 PM
@Benselic wrote:im past that but now im trying to port my number and it is saying my number isnt eligable to port
Koodo prepaid by chance?? If so you have to contact moderators to do the port.
Or via private message at link below
02-04-2020 08:31 PM
02-04-2020 08:22 PM
@Benselic Folks have mentioned that there's been issues with that earlier today, in various parts of the country. Either clear your browser's history, and try in Private/Incognito mode, or wait for a while and try again later.
02-04-2020 08:21 PM - edited 02-04-2020 08:23 PM
