Can’t activate esim
Truho
Brand new 17 pro max, can’t install eSIM, errors and says try again later
2 REPLIES 2
Frank52
Hi @Truho , which steps have you taken so far? Are you porting your number over from another carrier or are you an existing client trying to move the eSim from an old phone to a new one?
Sansan
Did you download the Public Mobile app to your brand new iPhone pro max?
That's the process.
If did clear the app cache, uninstall it and install again and go to Account and purchase the eSIM.
