Can't access data
Mojo2021
I can't access my data, please help
BlueB
@Mojo2021
After double checking that you still have data available for use (under your My Account), I would check your APN settings.
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Leave blank
APN type: Leave blank
Full details here:
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-set-up-data-APN-on-my-smartp...
Any luck?
@Mojo2021 ,
Ensure data option is turn on.
Try one or more of the below:
*turn off your phone, leave off for a minutes, then reboot
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
*reset network settings
HALIMACS
Alternatively, @Mojo2021 , you should also try typing this in the little white chatbot to the bottom right:
Setup APN settings
Then follow the directions supplied based on device you're using.
Welcome to Public Mobile!!!
HALIMACS
Are you out?
Check for any remaining from your current allotment here:
