10-18-2017 11:45 PM - edited 01-04-2022 02:47 PM
10-19-2017 03:47 PM
@will13am, the thread is actually from a year ago
But, it very likely still takes just as long to port over numbers from VOIP... ![]()
10-19-2017 08:36 AM
@davjho2, here is a recent thread on porting in from a voip service. Expect it to take a couple of weeks.
10-19-2017 06:13 AM
Howl long ago did you port your number? It shouldn't take more than a couple of days, but there could be some underlying issues that need to be resolved with a moderators' support.
Are you receiving any text messages at all? Does everything else work as it should (data, calls, outgoing SMS)? If the only issue is with the short code SMS, and it has been more than a week since you ported your number, I would go ahead and contact the moderators as explained here:
10-19-2017 05:28 AM
Hi @davjho2,
Porting can take a couple hours. Sometimes the port gets stuck and a MOD needs to look into it. You can send a PM to @CS_Agent with the details and they can look into it.
In the meantime, you can download some free SMS app like TextMe to get your short code and verification process going 🙂
Hope this helps.
10-19-2017 12:11 AM
I ported my number from a VOIP service to Public Mobile.
10-18-2017 11:59 PM
Did you port in your VOIP service? i am not very familiar with this service but im glady happy too helpp
