Can’t Receive Incoming Calls
Sami2
I just opened an account and ported my number from Virgin mobile I can make calls but not receive calls. Please help!!
2 REPLIES 2
MM9
I'm having exactly the same issue. Changed from Virgin to PM about 4 hours ago. Would be great to get the support # as well, please!
@Sami2
  A critical part to porting is to receive a text from your old provider , Virgin in your case, and reply YES within 90 mins.  If you are not receiving calls and text on your PM sim card and can only make outgoing calls,  then you might have missed the step and hence porting was not completed
There is a number to all to talk to live support and the can re-trigger the process for you.  I will message the number to you via the Community inbox.  Check the envelope icon on top right.  Call them and get it fixed
