Can't Log In/ Page Expired
bb6640
I cannot seem to log in to my account.  I keep getting a Page Expired page.  This has been going on for a while now.  I need to check the balance on my account and haven't been able to because of this.
1 REPLY 1
@bb6640   are you using Chrome and are you logging in with saved pasword?
If so, don't click "Login" after you picked the password from the saved list, let Chrome to login automatically for you
You can also try to NOT use the saved password and manually login or try using another browser.
it is more a Chrome automatic login issue.
