04-16-2021 06:15 PM - edited 01-06-2022 02:32 AM
Hello, I am wondering if anyone else is having issues with sending MMS (Picture) messages (MMS is turned on) from their iPhone? It says message send failure. Not delivered. My data is turned on. I am able to sent regular text messages and iMessages but I can not send MMS messages!
I have reset network settings and no luck!
I sent a support ticket for help and a Moderator did a reset of my network which still didn’t help!
I rebooted iPhone again and still no luck!
Any suggestions?
04-16-2021 06:23 PM
Try this:
1. Open Settings.
2. Tap on Messages (it should be about halfway down the column that starts with "Passwords & Accounts").
3. Tap on iMessage so the green toggle goes to gray.
Once iMessage is off, if for some reason you really want to restrict what content you can text, you can turn off MMS as well, solely leaving you with SMS.
04-16-2021 06:22 PM
@HALIMACS wrote:
Could be one of 2 things:
- you may have consumed your full data allotment, check in your self-serve to see if data allotment has been reached, or,
- you may be using iMessage or other services which may be needing to be adjusted in your message settings.
Hi, it’s neither of those.
04-16-2021 06:22 PM
you sure MMS is turned on?
Settings -> Messages and make sure the switch next to MMS Messaging is turned on.
04-16-2021 06:21 PM
