Calls
04-11-2023 07:34 PM
04-11-2023 11:57 PM
04-11-2023 08:36 PM
Did you reply to the text confirming you were porting over to PM with YES with old SIM in your phone?
This is the critical step in completing the porting process.
04-11-2023 07:39 PM
more info please...did you initiate a port of your old number to your new PM account ?
04-11-2023 07:39 PM - edited 04-11-2023 07:40 PM
Trying rebooting your device, resetting Network connections, removing SIM and then re install
Does your texting in and out, and data work?
If they do, and you can't get the calling resolved, contact the customer support agents.
- Use the ticketing system for a faster response time. Click here to create a support ticket, or,
- Send a private message to Customer Support Agent by clicking here. You’ll need to be logged into your Community account for the link to work.
