Calls
Rileybobo
I switched to Public yesterday but my calls go directly to voicemail and I do t receive verification codes
Rileybobo
Where will I see the msg with the phone number
Rileybobo
Ok thank you
@Rileybobo
Something else went wrong with your port then.  Since you are unable to receive phone calls and text messages. I will private message you the Telus/Koodo team porting phone number.  This can be only used for porting issues.
Rileybobo
I did reply and I can make calls and msg people
Dunkman
@Rileybobo
Your port may not have been successful.  Did you respond "yes" to your old carrier's port request confirmation text?  Is data working?  Are you able to do outgoing calls and send texts?
