Calls
ZH12
Hey guys, i need help with something, I can receive calls and texts, but I can't call anyone, when I try to it says "7b1 your phone isn't connected to the network
1 REPLY 1
hairbag1
@ZH12
what plan have you subscribed to ? Is it possible you have the older $15 plan with 100 minutes of Caanada wide calling ?
added...
also...try putting cell in Airplane mode for a minute...then disable Airplane mode and try your call.   Test your sim in a different cellphone (ignore if you use esim)
