08-01-2020 01:49 PM - edited 01-05-2022 12:38 PM
I can make calls and texts but I cannot get calls or texts. Please help me anyone!?
Service
08-01-2020 02:36 PM
08-01-2020 02:34 PM - edited 08-01-2020 02:34 PM
@JenL your SIM maynot have provisioned properly. Contact the moderators and ask them to reset your SIM. There are 2 ways to contact the Moderator Team:
- Faster response- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
- Slower- Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
08-01-2020 02:32 PM
No, it's a new number in our area.
08-01-2020 02:16 PM
@JenL Is he transferring his number from another carrier?
08-01-2020 02:07 PM
- Tap on Settings from the Home screen.
- Next, tap General.
- Scroll down to and then tap Reset to continue.
- Select the option to Reset Network Settings.
- If prompted, enter the correct passcode for your device.
- Then tap the option to confirm network settings reset.
Did you port a number? It can take up to 3 hours for the port to complete if from another cell provider. If from a voip or landline up to 7 days. If its been longer than 3 hours and the port is from another cell provider, then the port is probably stuck. Contact the modsrators and ask them to fix it for you. There are 2 ways to contact the Moderator Team:
08-01-2020 02:02 PM
1. From the home screen navigate to Settings>General>Reset
2. Tap Reset Network Settings
If prompted enter your passcode
3. Tap Reset Network Settings
4. Restart your phone
08-01-2020 01:59 PM
I'm going to try that now. Thanks!
08-01-2020 01:58 PM
IPhone XR
When we got the phone I put my SIM in it to test it and the IPhone received a call. We got the new SIM activated in Wal-Mart we put it in and it was working right away. I called my son twice already but, when we got home he noticed he could only make calls not get them. It has been reset.
08-01-2020 01:55 PM - edited 08-01-2020 02:03 PM
08-01-2020 01:53 PM
@JenL what's the make and model of your phone? Try a network reset and restart your phone if it doesn't automatically do so. Stay safe.
