Call forwarding
billtz
This does not work.
i tried every iteration. No joy.
@billtz
You will need PM CS agent to re-provision the account to have that resolved
Please open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗
    (if unable to receive 2FA via SMS, click "Didn't Receive code" or "Resend Code",
     then choose "
Send email" or "Send Voice Message" to get 2FA via email or voicemail)
billtz
Done and doner.
all I get is this:
@billtz
For unconditional forwarding, dial *21*1XXXXXXXXXX# (replace X with the 10-digit number) and call #21# to disable.
Or you can also go to the phone's dialer , click Settings and look for Calls Forwarding and update it directly there
