Call forwarding
friskefingers
Yeah does anyone know how to activate call forwarding from a phone number you don't have access to at the current moment to your current phone number both phone numbers are with public mobile and both phone numbers are owned by me
@BKNS27 wrote:
@friskefingers
You need to go to the phone you want to call forward to so if you don’t have access to…you can’t.
That's not correct. Call forwarding isn't set up from the phone that you want the calls to go to. It's set up from the phone that is using the service that you want to forward from.
slusagm
sorry, there is no way to set call forwarding without physical access to the phone, PM cannot help with call forwarding on behalf as well
@friskefingers
You need to go to the phone you want to call forward from so if you don’t have access to…you can’t.
Once you have access to that phone or SIM. Here is instructions for call forwarding to.
https://www.publicmobile.ca/en/get-help/articles/call-forwarding?_gl=1*dlbajv*_gcl_aw*R0NMLjE3NDI2OT...
