10-19-2020 02:50 PM - edited 01-05-2022 05:17 PM
Hello,
I have an unlimited Canada-wide talk plan and I’d like to use call forwarding over the next month or so. It is to a Canadian number.
When I follow the prompt on this help page to turn on unconditional call forwarding I get the message that “sorry, talk is not included in your current plan”.
thanks!
11-14-2020 04:23 PM - edited 11-14-2020 04:58 PM
@Vstj33 wrote:Hi, does the call forwarding work to a canadian number when I go out of North America? I see the fwd settings are applied at device level but not sure its done in the Public mobile database
While the user sets up call forwarding by using a device, the forwarding itself is done at the network level. If the call forwarding has already been set, it doesn't matter where you currently are.
11-14-2020 11:34 AM
11-14-2020 11:30 AM
10-19-2020 03:52 PM
Thanks, #21# got me a message that it had been turned off, but *21* still wouldn’t turn it on. Turning it on in my phone settings worked. Hoping that will continue to work when my phone is out of service (travelling outside Canada/US)
10-19-2020 03:51 PM
Thank you, that worked!
10-19-2020 03:46 PM
@Cheryl21 open your phone dialer app and go into its settings. try to forward your calls through there
10-19-2020 03:42 PM - edited 10-19-2020 03:45 PM
@Cheryl21 Enter #21# send first then try
*21*area code numbet# send.
Make sure assisted dialer setting is turned on.
10-19-2020 03:37 PM
@Cheryl21 wrote:Good idea, thanks.
Tried it and still getting the same error message.
Can you otherwise normally call that number? Are you sure it's a fully Canadian number and not some trick number to reach the states or something?
10-19-2020 03:12 PM
Good idea, thanks.
10-19-2020 03:07 PM
@Cheryl21 wrote:Hello,
thanks!
Try it with a 1 in front.
*21*11234567890#
