08-11-2020 04:27 PM - edited 01-05-2022 12:45 PM
Hello, my iphone 5 had a call forwarding option on and it fell into water. Phone is wrecked but when I use that sim in different phone and somebody calls me it forwards the call to my other number. Is there any way i can disable from public mobile end ?
08-12-2020 01:54 AM - edited 08-12-2020 01:54 AM
@Anonymous wrote:##004#
In this case, clearing of 'unconditional' call forwarding should also be done with ##21# (with the SIM in a working phone...)
08-11-2020 04:51 PM
@mohsiniqball2 wrote:Hello, my iphone 5 had a call forwarding option on and it fell into water. Phone is wrecked but when I use that sim in different phone and somebody calls me it forwards the call to my other number. Is there any way i can disable from public mobile end ?
@mohsiniqball2 Put the sim in another phone and disable the call forwarding feature by following the instructions:
08-11-2020 04:41 PM
@mohsiniqball2 , unfortunately, there is no option to disable/control call forwarding from within the self serve account. You will need to run a phone with the active SIM from the account to change call forward settings.
08-11-2020 04:37 PM
@mohsiniqball2 Place the sim card into a phone and Dial '#21#' to disable unconditional call forwarding. Stay safe.
08-11-2020 04:33 PM
##004#
08-11-2020 04:29 PM - edited 08-11-2020 04:30 PM
It can only be done from a phone. Borrow from a friend.
