06-17-2023 08:58 PM
@CS_Agent, i need the number transfer sent again.
06-17-2023 09:16 PM
@LWG call the number I messaged you and they will re-trigger the porting process
06-17-2023 09:13 PM
Sorry I need the process started again. Yes is not working.
06-17-2023 09:08 PM
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
06-17-2023 09:07 PM
Please leave your old active SIM in your phone and confirm with YES if you need the porting process restarted again then private message a CS_Agent.
06-17-2023 09:06 PM
Porting from Fido
06-17-2023 09:06 PM
Porting
06-17-2023 09:03 PM
@LWG Porting out or poeting into PM??
different procedure, let us know
