01-28-2026 11:03 PM
Hi there,
I just activated my new subscription with a physical SIM card and ported my number from Telus. Followed all the steps from the PM app and approved the port from my Telus service. When I insert the new PM SIM, my phone doesnt recognize it. Says "Please insert a SIM card to continue" if i go to my texting app. I tried repositioning the SIM, airplane mode, restarting my phone, resetting network settings, and gently wiping the SIM with a cloth. The old Telus SIM worked fine. Galaxy S25 phone. Can you please help?
01-29-2026 08:58 AM
Check this post, may it helps:
01-29-2026 01:01 AM
@CS_Agent I also tried to put the SIM in a different phone. Same issue, phone says there is no SIM. Also, since I completed porting, 2FA in PM app doesnt work since code is sent to phone number which doesnt have service due to SIM issue.
01-28-2026 11:15 PM
Hi there, it is not new. Used with Telus for 9 months before trying to switch to PM today.
01-28-2026 11:10 PM
Is that a new Galaxy S25 phone that has never been used? If it is brand new , it needs a sim to set it up. Try a different sim, maybe an active sim, to set it up first
