Billing!
Lia33
this is my first official month with PM. I’m supposed to have a 40$ per month plan. It says I will be charged 300$ on Aug 19. Help?
2 REPLIES 2
hairbag1
@Lia33
what you're seeing is incorrect and is just a glitch in the payment system. Should be fixed shortly...but you won't be billed $300.
slusagm
@Lia33
this is the 4th case today,  It is just a glitch on PM side.  The other community use the PM app to check and the amount was correct.  So, check and if the amount is right, ignore the wrong bill
