11-08-2016 07:28 PM - edited 01-04-2022 06:09 PM
My bill is $120 every 90days. I currently have AutoPay ($6) and Refer-a-Friend ($12). Does that mean starting the next bill, I will be paying a total of $102 (120-6-12) every month instead of $120. Thanks
Service
11-09-2016 10:52 AM
From what I read, only your auto play reward stays the same (as long as you sign up for it). As for Refer a Friend. It seems to change depending on rather they stay with PM.
11-08-2016 08:11 PM
Your autopay will stay at $6 for 90 days on each renewal, however your friend referrals, or community rewards could go up or down. Maybe next cycle you'll see 3 more friends, and $3 in community rewards, making your discount greater.
11-08-2016 07:49 PM
Hi, to clarify, refer a friend is $1 per month or $3 per billing period in your case. When you referred to $12, is that 4 referrals or 12 referrals.
But, yes, your math is correct. 🙂
11-08-2016 07:38 PM
yes
11-08-2016 07:31 PM
hi..
yiup, you nailed it.....
cheers
