Autopay
vickie89
My phone was cut this am, my payment wasn't due until the 22nd and I have autopay so I don't understand why it was cut ? Can anyone help me out here ?
8 REPLIES 8
@vickie89 if you renewal date is not for another two days, than this should not be an autopay failure, more like a phone, SIM, or network issue.
Did you try
If above or any other suggestions are not helping with services on an Active account contact CSA for help.
edited, removed 'plans are 30 days...and then some...' as already mentioned by @JL9 .
Akmb
@Akmb wrote:
Same here, Vickie.  Annoying to say the least.  My autopay was supposed to go through today, and they gave me the autopay $2 bonus, but they haven't charged the autopay portion.  I'm thinking I'll manually pay the bill and see if that works, since right now I have no phone service
Hey Vickie, I just added some money to my account, and just before I did that, the autopayment went through.  So now I have enough on my account to pay next month.  Maybe your autopay will be processed soon too
What does your self serve say? Suspended? Is there a renewal date? You said it is the 22nd are you basing that off of what you saw as your renewal date? (keep in mind it is 30 days so will always be moving around). Or was your activation on the 22nd and you are using that number for every month, because it is 30 days and not monthly.
Either way you can reach out to a CSA to investigate if your renewal date is indeed the 22nd and they can resolve it for you, and if your renewal date was yesterday/today you will just have to manually add the funds as it looks like there may have been an autopay failure
vickie89
I tried that
Akmb
MrSpock
@vickie89 hi dial *611 to see if your account is active it will also tell you your renewal date
vickie89
No data, no phone calls or text
JL9
When you say cut do you mean everything and your self serve is showing suspended? Or just data?
