Autopay
sshakkuri
Hi, can someone please help me setup autopay
HALIMACS
Hi @sshakkuri
Here's a Help article which you might want to reference regarding auto-pay:
Set up AutoPay (publicmobile.ca)
In order to set up AutoPay, you need a Self-Serve account, which you may likely already have.  Here's info on that you may find helpful.
Create a Self-Serve account (publicmobile.ca)
Triguy
To set up AutoPay, sign in to your Self-Serve account, select the ‘Payment’ tab, then ‘Register for AutoPay’. From here, you can sign up for AutoPay or remove the feature, if you no longer want payments to automatically occur. If you would like to change the card that is automatically charged, scroll to the bottom of the ‘Payment’ tab, then select ‘Manage my card’. This will allow you to update or remove your credit or Visa Debit card.
kb_mv
@sshakkuri  Go into your self serve account. Click payment tab at the top. Ignore the arrow in the pic, click Manage Autopay.
