07-21-2018 11:46 AM - edited 01-05-2022 05:09 AM
Payment
07-21-2018 12:58 PM
Thanks for the tag, @Lg85!
@mnozahy glad the note about matching exactly to the address on your statement helped. 🙂
07-21-2018 12:42 PM
@mnozahy wrote:Credit card is not expiring till March 2019
problem was with spelling of address
instead of 123 Main Street. I used 1234 Main St. (as printed in statement) and problem solve
Thanks everyone for your suggestions. It is first time I am using the community and I really appreciate everyone's involvment.
Glad you got it cleared up. Yeah a weird thing that St.isn't recognized as street but glad you received community support to help you figure it out.
07-21-2018 12:37 PM
07-21-2018 12:24 PM
I had a similar issue when signing up. Definitely leave the apt line blank and just use a hyphen.
07-21-2018 12:23 PM
Is it at all possible your credit card has surpassed it's expiry date? Or perhaps it's simply an issue with the servers and you could try again in an hour or so.
07-21-2018 12:21 PM
Courtesy of @srlawren, this was a reply from another fellow PM community member:
The address you enter for the credit card has to match exactly what you see on your credit card statements from the card provider. Capitalization, punctuation, spaces, etc. For example of the CC company puts your unit/apartment's number (if applicable of course) right into the main address like such as:
123-555 Main St.
Then make sure you enter the "123-555 Main St." as your address and leave the apartment number field blank.
07-21-2018 12:05 PM
I updated my address in the profile, but still same issue.
Thats the message i just got now
07-21-2018 11:56 AM
HI @mnozahy
Have you moved or changed your address recently? Make sure the credit card billing address matches the billing address in your Public Mobile profile.
07-21-2018 11:55 AM
Thanks for the reply. I tried with multiple browsers. Still same issue. It is very frustrating cosnidering that it was working well for the last 2 and half years. I will send the info now. Thanks
07-21-2018 11:50 AM
Frist try it different browser internet, make sure you put it correct information number your credit card, and you will see is working and if not work you need send a private message to Click here
In your message put it, please include.
- your account number
- your phone number
- your account PIN
- Detailed explanation of specific your issue
- them can help you a lot nice service Team
Good Luck
