Auto pay rewards
03-27-2020 03:11 PM - edited 01-05-2022 10:06 AM
03-27-2020 04:50 PM
@kimmycooper wrote:Awesome. The Best
Welcome to PM. There is no if or but as long as you qualify, you will get what is described in the plan details.
03-27-2020 03:29 PM
@kimmycooper to save more, add the TextNow voip app and use it via Wifi to make / receive / send calls and texts in Canada and to the United States for free. You can also use it as I do to check my voicemail from my own phone without using the minutes from the PM plan. Simply dial your PM phone number - reject the call when it rings (this sends the call to voicemail) - press the * key to allow you to enter your password. - enter - and viola you are in your voicemail account - Hang up when you are finished. No minutes used. Thank you
03-27-2020 03:23 PM
Awesome. The Best
03-27-2020 03:21 PM
@kimmycooper here's an article on switching plans https://www.publicmobile.ca/en/bc/get-help/articles/change-your-plan
03-27-2020 03:19 PM - edited 04-11-2020 05:33 PM
Isn't public mobile best? :cathappy:
03-27-2020 03:18 PM
@kimmycooper Yes, you will get both - 2$ off and extra data. Pretty awesome, right?
03-27-2020 03:18 PM
Ok But do I still get $2 off and the 250gb or just the 250gb
03-27-2020 03:14 PM
@kimmycooper once a autopay credit card is attached to the self service account. Then yes, you get the $2 and 250mb.
