02-18-2016 08:40 PM - edited 01-04-2022 12:49 PM
Hello
I was wondering if the following phones would be compatible once unlocked
Blackberry Priv
Iphone 5
Samsung S series
Or if there are any smartphones that would not be compatible
Thanks
02-18-2016 08:53 PM
To add to what @Martin was saying the iPhone and BB Priv should be fine and if the Samsung is a Canadian model you will be good but double check via the link Martin mentioned.
Good luck...
02-18-2016 08:52 PM
Hey @mibs000,
I know the BB Priv is compatible for sure.
iPhone 5 will work as long as its the GSM version = A1428. The CDMA iPhone5 won't work with PM.
Samsung S series is a very broad question. As a general rule you should verify that the phone has these frequency bands:
850, 1900 for 3G and 1700/2100 (band 4) for LTE.
The link provided above by @Martin is an excellent reference point as well.
02-18-2016 08:51 PM
Thanks for the replies. I checked the website but don't understand the reults... what am I suppose to compared them to?
Thanks
02-18-2016 08:45 PM - edited 02-18-2016 08:47 PM
Hello,
Unfortunately, the PM IMEI checker has a history of false positives.
To be certain about compatibility, go to www.willmyphonework.net
Cheers.
02-18-2016 08:42 PM - edited 02-18-2016 08:49 PM
They must be unlocked or locked to Telus or Koodo.
EDIT: Thanks Martin, use the checker posted below.
