Answered solutions
fdrcamb519
could someone tell me the difference when, I help someone, answer a question or some answers mine .
 whats the difference.......
gblackma
@fdrcamb519 the authored ones are the ones you get when you provide the correct answer and it's chosen by the original poster.
The marked accepted ones are the threads that you start,  that you accepted the answer to.
Stay safe.
Naepalm
Solutions authored are the solutions that you have given out.
Solutions marked accepted are the solutions that you have said yes
One is that someone selected one of your posts to be the solution to the thread.
The other is that you selected a post in your own thread to be the solution.
