03-05-2020 05:49 PM - edited 01-05-2022 11:04 AM
So Mar 5 amber alert goes of. So I acknowledge this alert, So I acknowledged this alert for everytime it come onit keeps on going of. So I shut the phone of. So everytime I turn the phone on I keep getting the alerts. It just does not stop. No matter how often I press the OK. SO the phone has become completely useless. I have turned the notifications on every app off, excet for the Calendar, the telephone and the text. Why do I have to put up with a useless phone that has been taken over by amber alerts.
Service
03-08-2020 02:06 PM
@amanda19 wrote:Maybe try taking the sim card out and putting it bak in. Or even resetting the phone completely.
This won't do much, the phone needs to the SIM to get the alert. Resetting the phone will only serve in data loss and still receiving the alerts after.
03-08-2020 02:02 PM
03-07-2020 02:51 PM
@Korth wrote:Consumer SMS/MMS apps all comply with SMS-CB protocols. I've searched exhaustively and found no exceptions on the online app stores so I'm guessing it's probably a legal mandate.
The only other options are to download pre-modded apps from the festering pits of the internet (asking for trouble once you install dirty runcode, so good luck with that) ... or to make your own modded app from clean opensource.
Guess I'm boned, I'm running a modded version of android 9.
03-06-2020 01:41 PM
03-06-2020 10:46 AM
With 5G on the rise, they will eventually kill off 3G altogether, so all networks will be on 4G/LTE and 5G will become the next LTE variant that costs what 4G/LTE did when it came out and 4G/LTE will cost what 3G does now.
My point is just that you can turn your 3G on for now till they decide to cut you off.
Blast from the past, if you will... (what you are looking at are the prices)
https://www.fido.ca/cms/pdf/brochures/BROCHURE_IPHONE_JULY_EN.pdf
03-06-2020 08:21 AM
I don't have the choice to turn LTE off. It stopped when I changed it to 3G, so now I will be on 4 G and when an alert comes (Which I do not mind getting) I can switch to 3G until after the alert is done.
03-06-2020 12:24 AM
03-06-2020 12:02 AM - edited 03-06-2020 12:30 PM
So you are saying you powered the phone off and continued getting alerts? Doesn't seem possible. How many seperate alerts were there? Couldn't really be that many could there though yes, if in the middle of the night it would be annoying. I have to assume "phone completely useless" is a bit of an over exaggeration? At least they seem to be fine tuning the area down now, not everyone in Canada is getting them all.
AE_Collector
03-05-2020 08:54 PM
I don't think they can be turned off entirely.
They want you to see these since they are emergencies.
I turned my phone on and off a lot today and each time I got a pop up alert. I pressed OK each time and that was that.
03-05-2020 07:41 PM
@wlgeurts wrote:So Mar 5 amber alert goes of. So I acknowledge this alert, So I acknowledged this alert for everytime it come onit keeps on going of. So I shut the phone of. So everytime I turn the phone on I keep getting the alerts. It just does not stop. No matter how often I press the OK. SO the phone has become completely useless. I have turned the notifications on every app off, excet for the Calendar, the telephone and the text. Why do I have to put up with a useless phone that has been taken over by amber alerts.
This topic has been discussed before. Amber alerts can be suppressed by forcing 3G connection.
03-05-2020 06:44 PM
03-05-2020 06:26 PM
Android
03-05-2020 06:25 PM
Have not tried that yet
03-05-2020 06:07 PM - edited 03-05-2020 06:17 PM
@wlgeurts try this solution here https://productioncommunity.publicmobile.ca/t5/Discussions/Did-anyone-get-the-AMBER-alert-last-night...
Especially the part about alert reminder timing.
03-05-2020 06:06 PM
@wlgeurts Android or Apple?
03-05-2020 05:59 PM
@wlgeurts What happens if you turn on phone without SIM or with SIM of other provider? Same?
