Amazon SIM
Phil1313
Just realized I ordered a Public Mobile Prepaid SIM Prepaid Phone - (Universal/SmartPhones) instead of an unlocked GSM SIM. I am on a subscription 5G @34.00 will I be be able to use the prepaid sim to replace my eSIM or does it require the more expensive unlocked SIM?
2 REPLIES 2
Phil1313
Prepaid card worked fine as replacement for my eSIM with no issue, as community said any new PM SIM will work, very easy process.
Phil1313
The issue I am concerned with is losing either my current phone number or plan when I enter the new SIM number since this is a "prepaid" SIM, I did not realize PM sells more than 1 type of SIM? I am assuming once I enter the new SIM my eSIM will be voided so if the prepaid keeps the assigned number I would lose my current number.
