2 hours ago
I haven't fully registered or selected a plan and already PM is pissing me off. I initially thought I'd go for the 65GB Canada US plan, but didn't finish selecting or registering it. Now I'm trying to change to the 50GB Canada US plan and it's not available!! I was liking PM, but not so much anymore.
How do I get the 50GB plan?
Thanks
2 hours ago - last edited 2 hours ago
PM changes their promotions every month so if you see a plan you want…just on it. Once you are registered, there are other plans for existing members.
I waited too long to switch from the $25 plan to the $19 plan with the same amount of data.
I ended up with the $23 plan with 6gb of data. I am at home most of the time and connected to the home wifi so I am a light data user.
You have to sign up with Public Mobile using the phone app. Please download the app and sign up that way. Once again, you may need to use a different email address. This is how public mobile works.
2 hours ago
It's from my desktop.
2 hours ago
Hey again @MaryAce
If you're using the app, just delete it and start again. Sometimes the app can be wonky. You MAY have to use a different email address though.
