08-24-2020 05:58 PM - edited 01-05-2022 12:55 PM
08-24-2020 10:57 PM - edited 08-24-2020 11:04 PM
@DaDiSi wrote:How do I purchase another sim and add a phone to my existing account
Re accounts and email addresses.
GMAIL Aliases will allow the same main email to receive all responses and allow login using the alias.
If using GMAIL. You can use one only GMAIL address as per below.
An easy way to sort your Email is to add categories after your username.
For example, messages sent to the following aliases used for different Public Mobile accounts will all go to janedoe@gmail.com:
Aliases
janedoe+MARYSPMACCOUNT@gmail.com
janedoe+FREDSPMACCOUNT@gmail.com
janedoe+DICKSPMACCOUNT@gmail.com
janedoe+JANESPMACCOUNT@gmail.com
janedoe+important.emails@gmail.com
For Outlook.com email aliases see here.
Copyright 2020
08-24-2020 06:47 PM
I can tell you that Canadian Cell Supplies is a reliable seller. I got the sim for $3 and it arrived in 4 days. Not bad for the price.
For a new account, you can use an email alias.
For example. if you have gmail, johndoe@gmail.com
you can create a new pm account using john.doe@gmail.com
08-24-2020 06:16 PM
thanks
08-24-2020 06:01 PM - edited 08-24-2020 06:05 PM
@DaDiSi each SIM requires its own account. There are no family plans here. You can buy a SIM online here, from Amazon and from Canadian cell supplies https://canadiancellsupplies.com/collections/latest-products/products/public-sim-card
08-24-2020 05:59 PM
One SIM, one account, one number, one email address.
