10-19-2019 03:19 PM - edited 01-05-2022 07:38 AM
I want to set up a second account for my wife and my question is if I use the "link" tab by my referal code it takes me to the set up page. Can I use my email adress so I can monitor both accounts easily? or do I use her email and the "link" just shows the second account in the drop down bar.
edited by computergeek541: removed referrences to using member's referrral code and referral link as per rules of this website
10-19-2019 10:11 PM
I found it. Very interesting. One email account with 2 unique email addresses.
See here. https://www.lifewire.com/create-gmail-alias-4580315
10-19-2019 09:51 PM
@GR wrote:@Lowufo to add to what I first said if you use a Gmail account you can put your email as xxxxxx+wife@gmail.com and it will still go to your regular email! Just add + and something after the regular email
I see what you are saying. 2 unique emails for PM. But same as far as gmail is concerned for receiving mail. But two different emails to log into PM. Do you have a URL to lead us to a more in depth explanation?
PS. Telus does allow ONE login to view two accounts.....each with their own account number. The same toggle shows on Telus and PM.
10-19-2019 03:32 PM
10-19-2019 03:21 PM
@Lowufo you need a separate email address but everything else can be the same!
10-19-2019 03:20 PM - last edited on 10-19-2019 03:37 PM by computergeek541
@Lowufo wrote:I want to set up a second account for my wife and my question is if I use the "link" tab by my referal code it takes me to the set up page. Can I use my email adress so I can monitor both accounts easily? or do I use her email and the "link" just shows the second account in the drop down bar.
Each account requires a separate email address.
