2 weeks ago
I bought an add on so I have data in the United States. I restarted my phone and removed my sim card but it still won’t work.
2 weeks ago
@NaomiJo wrote:I bought an add on so I have data in the United States. I restarted my phone and removed my sim card but it still won’t work.
Hello @NaomiJo
First, not all phones work in the US. Check the Volte list here by entering your IMEI number.
https://www.publicmobile.ca/en/get-help/articles/volte
If your phone is compatible, then go into your settings, carrier settings, remove automatic and choose either AT&T or Tmobile as those two are more favorable to work. Also, make sure data roaming is turned on. Once that is done, reboot the phone.
2 weeks ago
Have you enabled Roaming ?
